I can't find a post that shows anything definite saying you can't take the B3 to 78mm. I measured it once and found the opposite, BUT I didn't cut a block up to get a definite answer. I just mic'ed #1 wall through the water pump hole, so it wasn't a solid answer by any means.
I've read on here that the FSM gives nominal wall thickness. Personally, I can't find it in mine.
I've read elsewhere that the B6 doesn't mind being bored over 3.5mm and then being boosted to 23.5psi and DDed hard.
Till I see a B3 cut up, I can't quite believe it won't go to B6 proportions with ease.
YMMV
YMMV
