So, the B3 that has been in Baby Car for the last 4 years or so was bought for $200 with 190K on it. Roughly, it now has something like 400+K on it.
It has been running rough for quite a while now, and I haven't exactly done much to even figure out why.
Now, I have had this bad oil leak lately, both the cam and crankshaft seals under the timing cover. So, I broke down, and got the seals, as well as new timing belt, alt belt, and W/P. Gonna have to take them all out, right? Also grabbed new plugs, wires, rotor and cap.
I also figured I would do a compression test, get an idea of what was wrong inside. First thing to do, warm it up, then pull the plugs.
Sigh.
Then, there is the fact that number 2 hasn't been firing, unless the revs go over 1500, even before the spark plug somehow got closed.
Then the compression test
Round one
1st Took its sweet time jumping in a jerky fashion to 180 PSI
2nd creeped up to 150
3rd managed to ring up a whopping 30 PSI
4th slowly climbed to 115.
Squirt some oil in the cylinders, and then a second go around
1st rang right up to 170
2nd whomped up to 150, then crept to 165
3rd one shot right up to its previous heights of 30PSI
4th ran right up to 120
These are not good signs.
Some ring wear, oil, perhaps burnt or bent valves, or seats. Bare minimum, I have to remove the head, and I will spend at least $200, or $250, and then set that head on top of rings that show signs of wear, with 400K on them.
So, it is with a heavy heart that I feel I will just HAVE to install a B-6 in baby car.
My heart breaks
The good news is, for as bad as she runs, she is still running, and pulling, albeit not very well. This gives me a little time to make some moves.
I have found on carpart dot com, a B6 in a 1989 Mazda 323 with 123K on it, 20 miles from me, for $350, pulled. non-turbo.
Also, Silver is sitting over there, with a 5speed in it, engine out, since I gave it to WulfgartheGreat to get him running. Should be good, we found a burned up clutch when we pulled the engine. I SUPPOSE I could pop that in to replace the 4 speed I have been running on for the last couple years.
Then, I GUESS I could go ahead and clean the heck out of the engine bay.
What the hay.
The true bad spot is, I was GOING to go and pick up an aspire swap with sam.1956 this week, and it looks like this will kill that plan :cry_smile:
So, I used the search function, but my skillz there are terrible. Can anyone point me to a good thread or fifty on the swap, or care to share any pointers or tips?
Or did I post in the wrong topic...
Sigh.
Round one
My heart breaks
What the hay.
