Has anyone ever carboreted a b6t??
carb??
Why would they?
1990 Festiva L White: R.I.P.
1988 Festiva L Silver: R.I.P.
1989 Festiva L White: R.I.P.
Ya but if you can get a B6T, you'd have all the parts to run it EFI, which brings back to the question of why?
And anything you'd need to replace can be easily found on Rockauto, Ebay, and or the use of Miata equivalent parts speaking from personal experience.Originally posted by Damkid View PostYa but if you can get a B6T, you'd have all the parts to run it EFI, which brings back to the question of why?1988 Chevy Sprint Turbo 997cc
Originally posted by 88festivasam View PostI can't find a new Tps. Its for my capri. And everyone that says they have one must assume I onlly have monopoly money bc no one wants any of it. Lol
Where are you from? Cause if you're in the US, wouldn't there be a junkyard nearby you could look for one?
yes they are the same....Trees aren't kind to me...
To answer your original question, it would not be feasable to try and carb an EFI B6T. You would lose all the engine management control, plus, carbs and turbos don't mix very well. Yes, it's possible in theory, but there's a reason the car makers went to EFI on turbo motors as fast as they could (reference any of the carb'd turbo cars of the 1980s). If you had a carbureted car to start and decided to add a blow-thru turbo it would be different.Brian
They're the same between NA and turbo. If you have Capri parts needs - contact me first!! I have a massive pile of parts, and if I don't have it, I can point you where to get it. My buddy Russ has been running www.roo-sport.com for a year now & he can order new OE parts for you if NEW is what you need. And I know many other folks with parts cars, I've become quite the used parts peddler recently :p
Like I said: parts availability, especially electronics - NOT a problem with the Capri.
That being said, I have a couple GOOD USED tps' on hand - pm me if you're interested1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
