Dont judge
There are similar ones on ebay for less. You can get a wheel for $20, and the adapter. (Look for one thats good for the Miata or Rx-7) for less than $20. $40 total
Http://www.Youtube.com/TheresGabe
1991 Festiva L Red: Daily Driver
1990 Festiva L White: R.I.P.
1988 Festiva L Silver: R.I.P.
1991 Festiva L Red B6T: R.I.P.
1989 Festiva L White: R.I.P.
1995 Aspire 2-door White: R.I.P.
1995 Aspire 4-door Red: R.I.P.
That one is a little wild! I like it! I'm probably buying one as well! Can anyone who has used this type, verify that the horn will work?
The horn will work.
The round 320mm wheel is the same as mine, just different color scheme.
They use the same aluminum frame and wrap it in different colors.
The scoooped bottom wheel comes with the Miata adaptor, so should just bolt on. I had to order an adaptor and I ordered one for the RX-7.
With this wheel and the adaptor, there is good clearance between the wheel and the turn signal/wiper stalks too.
Some flatter wheels will cause your fingers to be too close, and hit the stalks, always turning them on. Annoying.Dan
Yup it's a direct swap like the factory wanted
I love the title of this thread BTW, you're on a forum but don't want opinions? Good luck with thatLast edited by Damkid; 10-11-2012, 04:14 AM.
Originally posted by Damkid View PostYup it's a direct swap like the factory wanted
I love the title of this thread BTW, you're on a forum but don't want opinions? Good luck with thatReD 91 L FIRSTiva
92 silver 5spd with some boost! Kratos
