I'm trying to rebuild a couple hlas for my car, I'd like to get a whole fresh set in there. I've got 10-15 hlas here in front of me, and I've messed with 7 so far. I can't get any of them to hold solid fully extended, 5 of them will push in halfway and no more, two are completely collapsable...this is after pushing the check valve in, collapsing the lifter to squeeze out old oil, then holding them in a cup of 40wt and collapsing them over and over and over until they build pressure and no more old oil comes out.
I'm assuming that they are supposed to be able to collapse halfway to keep the oil flowing through, but I'm not sure. These things sit right on top of the valve stem and are directly resposible for the valve opening fully, so I need to know if I'm right in assuming this is how they work, or if these are all junk? They have anywhere from 98k-175k miles on them. Most were stuck solid between halfway and fully extended, a couple were completely collapsed and wouldn't open at all without some carb cleaner, but those ones are the ones that hold the furthest open now.
