1. What's the best way to extract broken valve cover bolts if pliers and vice grips fail to work?
2. What is the thread/pitch/size of the valve cover bolts on DOHC B-series motors (B6T specifically if it matters)?
3. Are the VJ11 and VJ14 exhaust manifold to turbo gaskets the same internal size?
4. To adequately polish exhaust parts after carbon removal and porting, are 320 grit rolls adequate?
5. Because mine aren't long enough, what's the cheapest/best place to locate 6" shank carbide burs for porting?
6. If one has a ported and polished exhaust manifold, compressor, and O2 housing, is it worth doing the turbine as well?
7. Is there any source other than a leaky turbo seal for oil accumulating in the intake system and intercooler?
Please keep your answers numbered so I can keep track of the information. Thanks very much everyone!
