Compression test=Rocket science?
  • Compression test=Rocket science?
    So I bought a compression tester, and the hose is loose where it connects to the threaded adapter. What I mean is that I can hold the adapter and spin the hose, so how would I get it out if I threaded it into my cylinder head?
    mine has a hex head on the reducer, same size as a small spark plug...makes it easy to get it back out if it does come unscrewed on you.
    2008 Kia Rio- new beater
    1993 Festiva- Fiona, DD
    1997 Aspire- Babyspire, DD
    1994 Aspire - Project Kiazord
    1994 Aspire- Crustyspire, RIP
      Would you prefer the old compression testers, that had a conical rubber that you had to press into the spark plug hole with all your might while another person cranked the engine?
        Haha opposed to possibly getting a newer one stuck in my head, possibly hmmmmmm
          Im talking about the connector attached to the hose. No way I could get a wrench or socket on it.
            You won't need to thread the connector too far. When you feel resistance as you spin the hose, it's in far enough. Cross-threading would be my main concern here. Just go slow and you'll be fine.
              ^ That's also a problem, its like the threaded end has a bearing in it, it spins so how could I even tighten it in the first place? Must be a defect?
                If the connector isn't threaded to the hose, or have a 'quick connect' fitting, then I'm not familiar with it, sorry. Where did you purchase it? Got a picture or link for reference?
                  If I hold onto the part that threads into the spark plug threads. I can spin the hose. So its useless. Lol
                    Bought it at oriellys
                      never seen one that way. it should be tight. take it back andget another
                        I will probably do that, but maybe I'll jb it or solder it together.
                          That end is not supposed to spin. Take it back.
