Name that part!
  • Name that part!
    Okay, here is a chance to showoff your great Festiva knowledge!
    I have this part name request on another thread (Festiva Down!), but not everyone is seeing it there?
    So far no definite answers.
    Here is the part. What is the 2 prong connector at the bottm of the radiator? FYI, it is an 88 carbed Festy.
    Dan
    Radiator temp sensor.
    1960 willys pickup
    1967 jeep cj5
    1988 festiva
    1989 festiva
    1990 festiva for parts
    1991 s-10
    "Democracy is two wolves and a lamb voting on what to have for lunch. Liberty is a well-armed lamb contesting the vote!" —Benjamin Franklin, 1759
      edit: there's a more detailed thread out there, which explains it's purpose. I'll see if i can find it.
        So I assume I have the temp switch in the t-stat housing, coolant sensor on the block, AND a 3rd "radiator temp sensor" in the radiator?
        And just for all those who might wonder....the new radiators without the sensor does work just fine, at least it is working in mine.
        It seems they only make ONE radiator for our Festy's, and is made to cover all apps: Auto or manual. Just have to do without the sensor in the radiator I guess.
        Oh...Thanks to all you guys for the info!
        Dan
          I have that OEM switch. I never installed it in my rad. I guess I will just sell it since I don't have a computer.
            All the replacements I've ever bought have had a plastic plug in place of that sensor. Just remove the plastic plug, screw in the sensor and you're good to go!
            No festiva for me ATM...
              Is it a switch or just a sensor? Might not be so bad to know what the rad temp is, especially for the turbo and BP swappers.
                According to Ford in the 1998 EVTM pg 31 quote ... "Engine Coolant Temperature Switch" - "detects radiator temperatures and signals the ECA when temperatures are 62.2º (17ºC) The schematic on page 37 of the same manual shows it as a switch with the green wire going to pin 1L of the ECA and the black going to ground. It is used for control of the Positive Temperature Coefficient (PTC) Heater (Electronic fuel Evaporator [EFE]) the heater under your carb for cold run emissions compliance ... not used on EFI.
                Hope this helps. I replaced the radiator in my '88 VIN#30 and just left the wires off.
                Are there diagrams on this website?
                '88 LX (VIN#30) one of the first Built 12/86
                '88 L (VIN#55753) Built 12/87
                '93 GL one of the last Built 5/19/93
                  Wow, bravo sir.
                  Going old school...
                    A
                    http://www.fordfestiva.com/forums/sh...iring-diagrams
                    Post #1 shows the efi version only.
                      Engine coolant temp switch!!!LOL
                      Chuck
                      91 GL -Ol' Rusty
                      93 GL - Lil Red
                      91 L - Tweetystiva
                        Originally posted by KingFish View Post
                        Wow, bravo sir.
                        X2!
                        Well I dont have the PTC or EFE any longer. I swapped to a Weber a couple years ago and now have a B6 swapped into it, with the Weber.
                        Good info to know anyway! My new radiator dont have a place for the switch/sensor on the radiator, not even a plug to remove to install one.
                        Obviously I dont need one on my radiator as it will do nothing now.
                        Dan
