Working on bp swap feisty flywheel and starter but it doesn't want to kick out to crank thought it was starter so I went and bought new starter and no change any ideas???
Starter not kicking out
does the solenoid kick?
when you removed the starter, did you check for missing teeth?Trees aren't kind to me...
BP swap does not nessicitate a trans swap.... you can run a BP on an E series....Trees aren't kind to me...
I know that, I was refering to this:
(It's my understanding that you have to use the flywheel that came stock with the transmission. E-series is festiva, F-protege/escort w/bp. E series flywheel will not work with the F trans)Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
^except that the BP naver came attached to an F series, it's correctTrees aren't kind to me...
Yes i am doing swap identical to the np wtite up n N/A ENGINE brand new starter stock Festiva trans flywheel clutch and starter it wont grab89 festiva all of a mighty 1.3 Tha Black Bullet and good ole casper got casper when I was 15 and loved em ever since
is it possible the transmission shaft is not fully inserted or so trash in shaft hole.;
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
