front wheel bearings
  • front wheel bearings
    Howdy.....
    Can anyone confirm that the National A-18 is the correct front bearing for the 88-92 Festys?
    Thanks.
    Mark
    92 GL, 98k
    77 Chevy shortbed
    checking against Timken catalogue..... please hold
    Yes.... it is for '88-93 Festys and all Capris
      Coool.....the guy that I've had working on it said they were wrong, but everywhere I checked the a18's kept popping up....thanks bud.
      92 GL, 98k
      77 Chevy shortbed
        hmmmmm.....news is that the a18 is the outer only....the inner is a different number. more later.
        92 GL, 98k
        77 Chevy shortbed
          front bearings are all the same, inner outter left and right.
          the rear bearings are different inner/outter, but the front takes 4 of the same bearings, two for each side...
          festivas, aspires, and kia rios all use the same front bearings and seals ^.^
          autozone.com lists a18 as an alternate part number for front bearings, the easiest way to cross reference part numbers is to check rockauto.com, open a couple windows in your browser and use the "traditional HTML catalog."
          2008 Kia Rio- new beater
          1993 Festiva- Fiona, DD
          1997 Aspire- Babyspire, DD
          1994 Aspire - Project Kiazord
          1994 Aspire- Crustyspire, RIP
            The capri also uses 4x A18 bearings
            1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
            Rocketchips!
            Bolt-on Weber Carb Adapters!
