MPGs run, Aspire SE
  • mikeyjd
    replied
    OK, so you still have Festy brakes if you have 12s on. I'd put those 185/65x12s on the rear and look for larger front tires, like even 155/80x13s, which are 22.7" tall vs. 21.5" for the 185/65x12s.
    But frankly I'd call the sweet spot about 24", which is a good 10% taller than stock 12s, very available, and can be used on "normal" rims. The Kumho Solus KR21 comes in 185/75x14. It is an excellent, long-wearing all-around tire, and at 24.2", you will have little or no front fender clearance issues, since the wheel/tire won't be sticking out from using a large spacer. Worst case, you might have to roll the front fenders a little. I think that the higher gearing it provides will more than offset the extra drag of a wider tire (compared to a 155).
    Check out this selection at tires-easy: http://www2.tires-easy.com/cgi-bin/r...hen=View+tires
    The Hankook is also good and quite cheap. I might stick these on my Capri 14" rims for the Festy.
    so capri 14's would be an ideal swap if i wanted to use my current break setup without any kind of adapters?
  • TominMO
    replied
    Just checked the alignment. It is still 1/4" total (1/8" per side). I will change it to zero after tmw's test, because I have heard on the forum that it gives better mileage. Don't want to change it now since that will introduce another variable. Also, tmw I will pay attention to the steering pulling right issue. Hopefully it was related to the tall tires, as I now suspect.
    Or maybe I was driving with the parking brake on....
  • TominMO
    replied
    You know, now that I think about it, with the tall heavy tires on front, it did seem to be pulling fairly hard to the right....think I'll go out and check the alignment again, with the normal tires on.
  • Movin
    replied
    Its hard to tell looking at the pics but it looks like the front tires are offset to the outside
    quite a bit. That could compress the springs more changing the toe. It probably just looks
    that way. My car toes in quite a bit with 1/2 inch change down in height, so I don't mess with the coil overs much. Yours may not change as much, it all depends how you are set up.
    I suppose you could rig a rope and fish scale to "weigh" rolling resistance. Try the different wheel tire combos you have collected. You are too careful and I can't see you messing up a fill, there has to be other reasons!
  • TominMO
    replied
    Originally posted by Movin View Post
    With that many changes did you re align the front end ?
    Nope, left it as it was, which was pretty good.
    Here is a useful list from Kumho on tire sizes, weights, and widths on specific size rims:
  • Movin
    replied
  • TominMO
    replied
    Originally posted by Spike View Post
    Actually considering buying 4 spare tires..
    Never realized how awesome they look!! They look like '70's Mopar wheels.
    -Joe
    You would need thick spacers tho, and long studs to mount them. And they are heavy steelies.
    Just went out and weighed several tire and wheel combos. Used a cheap bathroom scale, so FWIW:
    Weight.....Description
    13 lbs......Aspire steelie, no tire
    22 lbs......very used 185/70x13 on old aluminum AR rims
    22 lbs......new 155/80x12 on a Metro steelie
    28 lbs......new 155/80x13 Firestone Winterforce on Aspire factory aluminum rims (winter tires are apparently heavier)
    31 lbs......new 165/80x15 tire on Accord space-saver steelie
    So given the 31 lbs (+ 1-2 lbs adaptor) of the tire I just used in my test, compared to my usual 22 lb tire/rim, maybe the extra rotating mass was an issue after all. Makes more sense than a fill error, since all my previous results seemed reasonable given the curcumstances. But I'll see with the next test: full aero treatment, original tires.
    Edit: here is another thread on tire and wheel weights that I started a few years ago.
    Note that Aspire steelie and aluminum rims weigh about the same!
  • Spike
    replied
    -Joe
  • TominMO
    replied
    Just came back a little while ago from doing another MPGs test. Same 99.1-mile hwy course, same perfect weather. Changes to the car were taller 165/80x15 tires, and more aero mods. I even made rear-wheel skirts this morning, out of some styrofoam I had laying around and the last of my white duct tape. Total aero mods to date have cost less than $30 in materials.
    See pic below. (Included is a bonus pic of the cat who owns me.)
    The results were surprising and disappointing. It took 1.88 gallons to refill, at the same pump I always use. This came to a MPG figure of 52.7! This despite the fact that on a roll-down test, it took a long time to lose speed, and was significantly quieter inside the car (lower radio volume needed), indicating less air disturbance. Engine RPM was down from 2700 to 2400, the same as my Festy's @ 60, due to the taller tires.
    What I am thinking is: fill error. Need to do a longer test to get better results. It could also be that I had a fill error on the previous run (when refilling), so that my result of 55 MPG was not accurate. So for now the jury is out. I just need to do a longer test.
    The other possibility is that the 15" steelies and tires are so heavy that it took more gas to keep them rolling than was gained in lower rolling resistance or lower RPM; but I don't really believe that. BTW these tires are just too tall for everyday driving; lotsa scraping of the fender liner happened on turns or small bumps.
    Tmw I will do another identical test with my regular 185/70x13 tires on front to see if that was an issue. It will raise RPM back to 2700, but on the other hand it will also lower the front of the car by about an inch. Possibly that was also a factor, but again I doubt it based on how quiet the car was.
  • TominMO
    replied
    Lets get good enough mileage that yo mama slaps U !!
    Yo mama is so dumb, that when she heard most car accidents happen within 25 miles of home, she moved!
  • Movin
    replied
  • TominMO
    replied
    Here is my Aspire, completely modded for its test....
    Notes:
    Front tires are 165/80x15 on 1992 Accord space-saver rims.
    Dagnabbit, another error! Fixed it for me.....
    Other JY sources for wheels for this tall skinny 15" tire (from the 4-hole wheel list):
    4x100......1998 Acura Integra 15 x 5.5 (11 Y-type spokes)
    4x114.3....1989-90 Acura Legend 15 x 5.5
    5.5" is as wide a rim as you would want to go with a 165mm-wide tire.
  • TominMO
    replied
    Mis-spoke in post #29 for a tire recommendation size. Should be 185/70x14, not 185/75x14.
  • TominMO
    replied
    Here is my Aspire, completely modded for its test, shown on the grounds of the IAAAS (Institute for Advanced Automotive Aerodynamic Studies).
    Mission Statement of the IAAAS: to create vehicles of such high MPG ratings that you will want to slap yo' momma.
    Notes:
    Front tires are 185/80x15 on 1992 Accord space-saver rims.
    Rear tires are just some 155/80x13 snows I had laying around on Aspire steelies.
    Side skirts are temporary and mainly held on with 90-MPH tape. Since I will only be going 60, this should be fine.
    Had to remove front mudflaps due to rubbage.
  • TominMO
    replied
    Originally posted by mikeyjd View Post
    Awesome info Tom! I am trying to figure out the 100% best option for my current tire/wheel situation. I am taking my time as I got some brand new 185/65/12's given to me last month and I want to get at least a little use out of them even if they are only 22" total, and it will take me quite a while to pay off new 14's or 15's since I'm already at 60mpg with the 12's.
    Edit: my car has a nice auto festy vacuum booster for the breaks and new calipers and pads as well so my breaks are top notch, and wouldn't want to invest in a new setup. It sounds like an adapter is my best bet, but I would want to avoid protrusions that would be counter productive. Thoughts?
