least expensive e box performance clutch
  • bobbyspider
    replied
    ^ this is def good stuff to know for the future. wish dickmeyer would have had your g box mod when he was running is monster b3 build because the trans and axles just couldn't handle it
  • JPT
    replied
    Originally posted by bobbyspider View Post
    wouldn't mind having a g at all. can the 01 rio g bolt up to a b3?
    the Rio transmission should bolt up to any B series engine (probably the Z series too). You would need the flywheel (and matching clutch), the starter and the block plate.
  • bobbyspider
    replied
    Originally posted by JPT View Post
    Notice how this thread has gone from cheap E series clutch to an F series install.
    Why stop there? Get a G
    I got mine from a friend who works at a parts warehouse. They're on eBay for right around $100.00
    Keep in mind that I'm running a Kia Rio 5 speed. I don't know if they have E series clutches.
    Sachs makes good stuff.
    Just looked. They do have E series clutches.
    This one is $82.00 shipped.
    http://www.ebay.com/itm/SACHS-K0071-...8a6f28&vxp=mtr
    why the f-bomb did I miss this!? still think im going for the b6 and f box cause its a double win for me. I get a clutch/better trans out of the deal. win - win then I can sell flamer to my friend win - win - win then he can become a member win - win - win - win... pickin up what im puttin down.
  • JPT
    replied
    Originally posted by sc72 View Post
    I would like to know more about the Sachs clutch, were do I find it, money, etc.
  • JPT
    replied
  • sc72
    replied
    An Exedy clutch might work for you. When I put my B8 in the car, the used one I had (about 50,000 miles) held it for about two months before it began to slip.
    The Bahnhof slipped from day one, even after babying it for the first 500 miles (like they recommend)
    I'm running a Sachs clutch right now. Can't make it slip no matter how hard I try.
  • bobbyspider
    replied
    i thought the point was to hold power and not have to fab mounts.
    Well my brother if it comes to modding 1 mount vs changing a whole flywheel or spending 180 on a decent clutch and im only paying 200 for a superior trans and it comes with a motor attached to it.... What would you guys do. Input?
  • Zanzer
    replied
    The E series use a 7 1/8" clutch, swapping to the F series gets you a 7 1/2" clutch or you can swap in a B6D flywheel and bump it up to a 7 7/8" clutch. That should hold more than your B6 can throw at it
  • FestYboy
    replied
  • JPT
    replied
    I was going to do an F at first, but then the Rio was discovered to fit. Both take a clutch that's larger than an E, so they'll hold more.
    An F series with an Exedy clutch will probably hold all that your B6 can dish out.
    If you like rolling the street with a lot of gear, you might want to look at a Rio trans.
  • bobbyspider
    replied
    Or i could get this f series i just found with a b6 attached for $200. Is the f a better upgrade than just a spec clutch? I kinda know the answer but how good an upgrade is it.
  • JPT
    replied
  • FestYboy
    replied
    what does insurance have to do with machining a piece of metal? if the holes are drilled to fit the pressure plate and you use proper fasteners, there won't be an issue. machinests are used to dealing with .0001" tolerances, if they cant center a pressure plate, then they shouldn't be working there.
  • bobbyspider
    replied
    Originally posted by drddan View Post
    ^ Yeah, me!
    Bahnhoff clutch in my Festy now. It slips when shifting if you get on it. I think the stock festy clutch would have been stronger!
    Looked at reviews on line and some peeps have reported the same thing, and I believe there is a another member that got the Banhoff and it slipped on him.
    The price makes it tempting, but i'd spend the few extra $$$ and get the exedy. If running a B6 the stage 1 racing clutch would be a better option.
    DON'T BUY A BAHNHOF!!!
    I bought one and it slipped more than the used Exedy I had.
    Sent from my SPH-M930
    Originally posted by sketchman View Post
    I'm looking at a F1 Swift clutch, myself.
    Probably what I'll end up going with when I do. They seem to get good reviews, and the little bit of work it takes to make it fit the E is trivial. I would even consider using some big washers under the pressure plate instead of machining the flywheel to make it work. But that's really because machine shops suck here. Either way, bang for buck, it's a pretty good deal.
    http://www.ebay.com/itm/151055120367...84.m1423.l2649
    I looked at the swift clutches too and the write up to do the conversion. the only thing that intimidates me is the machining process and re pinning and redrilling for the bolts and all that stuff (umm that's actually the whole process lol) I don't know how much a machine shop would charge and if they would even do it because of insurance reasons and what not. Im on a limited budget but cant stand not upgrading because it seems like such a waist of time to put a stockie back in there and replace it again in 2 years and cant seem to make my wife understand that lol she just thinks I wanna play... you married guys get my point. how much do you think a machine shop would charge to do this? any input here woud help me make this decision because I gotta make it quick because shes pretty much gone and im driving the bp with no inspection and a bad axle all so frustrating and typical at the same time lol. any input on price?
  • sketchman
    replied
