So here's an idea I've been debating.
I would like to have a bit more CFM from my air compressor so I was thinking about using a B3 as the compressor unit.
1.3 liters = approx. .045 cubic feet.
If the engine was spun at 1000 rpm's that should give 45 CFM which would be plenty of volume i would think for lighter sandblasting.
Thoughts on the engine configuration (in my mind anyway) would involve;
Making/fabbing a cam gear so a 1:1 ratio is acheived with the crankshaft.
Disabling the exhaust valves so they don't open.
Using the sparkplug holes and manifold them together to the tank going thru a check valve/pressure relief system like a normal compressor.
The above mentioned modifications should in theory allow the intake to open on every piston down stroke, compression/release of compressed air on every up stroke.
Retain the water pump and radiator to hopefully dissipate some of the heat caused by compressing air.
These are just some of the things I've come up with. Possibly use a 330 gallon LP tank for storage.
I would think a 240 volt 5 HP motor would spin this contraption OK.
Possibly my calculations are off and someone could explain where i went astray.
Thanks.
Thanks.
