Long story short, work van isn't plated or insured, and gearbox is getting questionable, and caliper hangs. Toolbox on wheels for the 1400 unit apartment complex I work at.
I need fuel, and she's getting rough to roll down to the station.
Idea, splice into fuel return, pop hood, string out a hose, flip valve, presto. Reflip valve, Wind up hose, twist a bolt in the end to keep out dirt, , close hood.
Only valve I can think of that might work without actually investigating, motorcycle/atv on/off/res. Ideas?
I'm not worried if I need to hit the gas station two or 3 times on the way to work to get a full tank. It's 23gal and lasts me 2 months at a time. I figured this is much easier. Already a tank under car, why not use pump to move it where I need? No funnels, bulky 5gal tanks. No spills. 5 mins of idling should spit quite a fuel out the return hose.
Sent from my rooted HTC Supersonic using Tapatalk 2 Pro
