tire size
  • tire size
    will 175/70/13's fit without rubbing.of course I have the aspire swap
    What rear struts do you have, Festy or Aspire? Festy rear struts have a lower spring perch, which is where most of the rubbing issues come from. If you have the Aspire rear struts, you will be fine. I doubt wheel offset will be a problem with just about any FWD wheel you are putting that tire on, 4.5 or 5 inches wide.
      aspire rear struts on both of my cars cars. that is the factory original struts that were on my aspire swaps.you know just moved to the festy's but im running stock festy springs on one and rio fronts and aspire rears on the other.
        Well all righty then, you should be good to go.
          sweet thnx tom found some Hercules on craigslist 1week old for 80 bux score
