anyone rebuild them or steer me in the direction of a rebuild kit for one not just seals
does anyone rebuild manuial rack and pinions on here
Send a pm to M3ntal. He was offering kits and I believe he also rebuilds them.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
I rebuilt an aspire manual rack with marks bushings, I was having some major steering issues at the time and I swapped in 3 different racks, but the problem didn't change regaurdless, so I can't say the result was good or bad.
Aspire racks interchange with Festiva racks, the thread pitch for the inner tie rods is the same, and the mount locations are the same, but the gear inside the aspire rack is thicker than the Festiva rack by enough that marks bushings won't work unless you bore them out a little more. It's easy with sandpaper but if you go a couple thousandths too far you'll feel slop in the wheel. Also mark uses a set screw to press the bushing against the gear to hold it in place, it popped out on me, then I tightened it down more and the bushing cracked and a chip fell out. I drilled holes in the bushing and used longer set screws to prevent lateral play 180* apart.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
I've re-built some as well - a manual festy rack just fits in one of the USPS flat rate boxes that costs around $17. I should re-build one or two and do it as an "exchange" program. I make delrin bushings just like mark did.
Not trying to steal his business... but if he can't get one done for you let me know and we'll work something out.~Nate
Current cars:
FOTY 2008 winner!
How much would you charge to rebuild two for me? I and will bring them to you at madness 704-794-2041Originally posted by skeeters_keeper View PostI've re-built some as well - a manual festy rack just fits in one of the USPS flat rate boxes that costs around $17. I should re-build one or two and do it as an "exchange" program. I make delrin bushings just like mark did.
Not trying to steal his business... but if he can't get one done for you let me know and we'll work something out.Barbie Car - '90 L-plus_2nd Gen SOHC B6+rear turbo @ 8 psi
My southern find has the power rack, and they ran it with no boots, and you can easily clock 11-1 and nothing happens. Heh. Reason I asked if the rack and pinion were the same between power and non power assist.
Sent from my rooted HTC Supersonic using Tapatalk 2 ProLast edited by jason_; 09-24-2013, 06:51 AM.
Someone gives me some serious tight #s I could turn something on the lathe.
I don't have anything handy to tear apart that's not dd, and the one that is apart I don't know what a good factory measurement would of had been.
Sent from my rooted HTC Supersonic using Tapatalk 2 ProLast edited by jason_; 09-24-2013, 12:04 PM.
Oilight Bronze would be better than brass. Wears longer and is impregnated with oil.Originally posted by 1chrisapple View Postso who thinks that brass bushings could be made for the rack seems like it would work
Corksport makes shifter bushings out of the same material.Last edited by drddan; 09-24-2013, 12:35 PM.Dan
looked it up and wow it's not cheap by anymeansOriginally posted by drddan View PostOilight Bronze would be better than brass. Wears longer and is impregnated with oil.
