On the way to work, dark and raining, I put the headlights on. I only ever, since owning the festy, had just the high beams. I already ordered new bulds and was going to replace them for starters this weekend, they are on the way..
lights came on then went out. I have parking lights and dash lights. The bright light indicator on the dash is out. By reading a couple posts here, figured it might be the relay. I am many miles from home and most my tools. is there a quick and easy way to by pass the relay and hot wire until I get home.. still raining and it will be dark on the way home... by the way this past weekend, i did put a meter on the headlight bulb harness and had voltage which made me order new bulbs. 12v on low and 12v on high beams, even though only high beams worked..
just need a quck fix ideal today..
Thanks
David
93 L
Thanks
David
93 L
