Need input on my Festivas cylinder head
  • Need input on my Festivas cylinder head
    Trying to see what other head would work with my Festiva
    The only other one is Aspire.
      Oh alright, was wondering if there are any other 4 cylinder cars where their head will work with a festiva.
        may i ask why?
        i don't think you would gain anything.
        even if a b6 head would work.
        just see your wtb
        yeah aspire of festiva is really your only choice
          Alright thanks, and was just wondering because ima be going to the junk yard for a head
            FYI... the Aspire head is a roller rocker head, a Festiva head is standard stamped steel rockers.
            An Aspire head would be slightly better, and maybe a little less wear on it as it will be newer. Check mileage on whichever you pickup.
            Dont know for sure, might have to use th VC from the Aspire also. Heard it mentioned the Festy VC was not tall enuf for the rollers. Dont know this as fact though.
            Dan
              Thanks alot!!
                There are very few if any generic engines with interchangeable heads. B3 is your preferred option. I'm told that B6 might just bolt on but location of chambers, valves and ports etc are likely slightly off. Don't risk it. If you find an Aspire engine make sure you grab everything but the manifolds. I'm preparing a 97 B3 at the moment and have already noticed that a Festy valve cover gasket (88-93) B3 is not compatible with an Aspire cover even though they look to be the same.
