quick dumb question
  • quick dumb question
    I'm assuming that since the engines are the same that the transmissions are the same on the aspires but I want to be sure before the junk yard rapes me for it. Thanks again guys
    You are correct they are all the same
    -90 festiva - bp swap "relentless" (thanks matt) aspire swap, pacesetter, underdrive pulley
    -90 festiva - surf blue (undetermined destiny) wanna keep but wifey says noooooooo
      different final drive and brackets arnt the same.
      but it will work just rev higher in 5 th.
      mam assuming you mean festy to aspire.
        They are not the same...
        Ones automatic
        Ones manual :-)
          If it's 94-97 Aspire to 94-97 Aspire you are comparing they will be the same. Festy vs Aspire are not (gear ratios are different) but they can interchange with a little bit of mounting bracket work.
