sup all? i have seen others use different injectors from other cars for various turbo setups. for example i think there was someone here who use scion tc injectors?. my question is are there any other injectors from other cars that would work? someone offered me some turbo supra injectors and thats the biggest reason im asking but also want to know what other ones that are factory from other cars may work. -thanks
fuel injectors fom different cars?
I use 1991 rx7 turbo "trailing injectors" they are 550cc and same plug as stock Festiva.
Time to do some reading....
witchhunter.com look at nippondenso injector pics....
Scroll down to denso top feed.
-Greg
Redneck Engineer
FOTY - '09
Look at a stock injector you have laying around. It will have a 195500-????. It will tell flow etc.
Yes you can use B6t injectors in a b3t, but without any way to tune them it will run bad. You can get a matching vaf meter/ injectors.
Cheapest, easiest way is to use stock injectors with an FMU. Matt uses or used to use that setup. I also ran one for a long time. It allows up to 10 lbs of boost.-Greg
Redneck Engineer
FOTY - '09
ill have an fmu this weekend and for some reason i do have an rx7 vaf. so i need to find the injectors that match that vaf for a good bpt setup and a tuner like a safc2 for example.
and for the b3t i can use the b6t injectors but i should find a vaf to match.
am i on the rite track? i thought gauge used stock scion sc injectors with his setup?
