GT-X inst. cluster pic
An actual low-fuel warning light! I wonder if that unit is plug&play with any Festy to get that feature. I bet it is.
Shortly after buying my first Festy, I discovered the hard way that it didn't have that light.....90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I have decided not to attempt the digital cluster install. If anyone is braver than bravekozak, and wants to attempt it, then PM me.Last edited by bravekozak; 11-01-2013, 05:47 PM.
Hmm looks familiarOriginally posted by getnpsi View Post
i believe there is a mistake here: all GT-X clusters are based off the 323 cluster shape (like the 2 pictured above) or the Digital units of the same shape. the unit in the first post should be from the Festiva GTA (JDM market ONLY) DOHC 1.3L.Trees aren't kind to me...
Arty you're wrong buddy, the pic I posted is of a 323 GTX cluster that's in my festiva
The first pic is of a festiva GTX cluster
The 323 GTX cluster is thick at the bottom where as festiva clusters are thick at the top.... Basically the contours are opposite making the 323 clusters a ton more work to install, not to mention wiring work etc
Im gunna assume the festiva GTX cluster is like any 180kph/110mph tach clusters that were overseas, they had different circuit boards with different wiring plugs, so they're not plug and plug with north American festiva's, however US tach cluster circuit boards are a direct swap onto the overseas clusters making them plug and play, but also makes the low fuel light and door open light uselessLast edited by Damkid; 11-01-2013, 10:30 PM.
So in other words, 60 dollars is a solid buy for the one I linked to. I corrected my mistake. Festiva GTX stuff is darn interesting the more i learn and read about them, but to own tangible upgrades continues to do it for me
Damkid, did you take the time to wire everything? Does the fuel light come on w/your 323 dash when the resistance is at a certain point on its own with the needle or it's a separate module? I experienced this in my neon when i changed my fuel pump. I thought everything was exactly the same, my gauge works but my low level light doesn't light anymore.
Might as well jack this thread more. A member on here used a 626 orange cluster too and id like to learn about that surgery as well anyone know?Last edited by getnpsi; 11-01-2013, 10:59 PM.1993 GL 5 speed
I didn't actually do the install of the cluster, a previous owner did, basically he re-pinned the 323 cluster connectors with the festiva wires so it looks factory, but I'm assuming the 323 ECU or fuel sending unit triggers the low fuel light because it doesn't work... It'll light up when the engine is off and key on though.... Otherwise the cluster works like factory, I even kept the tach working properly when swapping in the V6 by getting a tach adapter lol
Does that physically fit in the Festiva dash or is it too wide like the other digi clusters I've seen?Originally posted by bravekozak View PostI have decided not to attempt the digital cluster install. If anyone is braver than bravekozak, and wants to attempt it, then PM me.
Also assuming it's not a mechanical speedo so an electronic sending unit like found in a Kia rio would be needed?Last edited by zoom zoom; 11-02-2013, 04:44 AM.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
I wanna see a old rx7 cluster stuck into a festiva or bf car. those are plentiful and match interior as well. no one has documented how to make the rotary signal go back to 90 degree firing1993 GL 5 speed
stefan installed one. Do a search for "digital cluster". You assumed wrong this time. It's a mechanical speedo. You are correct. It's a little too wide to fit without modification. But it sure looks nice when lit up.Originally posted by zoom zoom View PostDoes that physically fit in the Festiva dash or is it too wide like the other digi clusters I've seen?
Do you think a Korean Laptor is too corny?Last edited by bravekozak; 11-02-2013, 06:19 AM.
IIRC the 323 clusters are a friction-fit; you have to remove the mounting ears on each side, then slide the cluster in.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
ok, totaly brain farted about the Festiva GTX. But i can't seem to hunt down a cluster pic of a GTX, and that also bring up the point: what does a GTA cluster look like?Originally posted by Damkid View PostArty you're wrong buddy, the pic I posted is of a 323 GTX cluster that's in my festiva
Im gunna assume the festiva GTX cluster is like any 180kph/110mph tach clusters that were overseas, they had different circuit boards with different wiring plugs, so they're not plug and plug with north American festiva's, however US tach cluster circuit boards are a direct swap onto the overseas clusters making them plug and play, but also makes the low fuel light and door open light uselessTrees aren't kind to me...
