I have a 1990 Festiva auto trans and it wont shift properly. You have to get up to 25mph to shift out of 1st and 53 mph to shift out of 2nd ?? Any Ideas on this problem.
Transmission Shift Trouble
Have you checked/changed the fluid in it? I'm thinking modulator valve but I haven't located it in my manual.
Also I'm thinking that a clogged filter might make it do that.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
Isn't there also a vacuum line that goes to it? Once leaking, it does something funky if I remember my reading.White '92 GL 5-speed BP, G series, Aspire/Rio swapped, "Nancy"
1988 LX 5-speed
1993 L 5-speed B8, E series, Aspire/Rio swapped
Gone:
I forgot to put vacuum in the modulator name but yes it should have a vacuum line attached to it.Jerry
Team Lightning
93 L Lightning. BP
check your vac line to the trans, if it's leaking the trans thinks you're accelerating hard and will push the shift point higher in the RPM band.Trees aren't kind to me...
You may have to adjust the vacuum modulator. There is a flathead screw in the nipple the vac line goes to. In the ford service manual, there is a page directing this. Can't find mine though, the garage got packed for the winter.-Zack
There are several threads with the main topic being vacuum modulator so I just choose this one to do a post.
RockAuto has a closeout vacuum modulator listed for $4.39. The others listed start at $41.
O'Riley has one for $19.99 (Pioneer) that does fit the Festiva.
I ordered one (KEMPARTS VM605) from Rockauto and it does not fit.
I contacted RockAuto and they say they are not mistaken and it does fit and refuse to remove the link to the parts as fitting the Festiva.
About every other vehicle that it shows as fitting are 1972 Fords.
So do not order one of these KEMPARTS VM605 modulators for your Festiva.
They say they have had not complaints about it not fitting the Festiva before me.
You can see from the pictures in the RockAuto online catalog that it is completely different.
The threaded nipple is much smaller on this one and it has a wrench fitting.
Anyone ever ordered one of these from RockAuto?Last edited by 1990new; 04-27-2016, 04:23 PM.
Please clarify.. The vacuum modulator on my 1992 GL screws in. Look at the picture of the modulators listed in theOriginally posted by bhazard View PostFestiva modulator: Press in and secured with bolt
Aspire modulator: threaded in, NOT the same as a 1972 Ford anything. I believe the Mazda MPV one works.
online RockAuto catalog. All three of the non closeout ones listed for the 1992 Festiva look like mine and it is not pressed in.
Are we talking about the same thing? this screws in behind the Step down switch (which also screws in) and has a vacuum hose attached.
I just wrote a scathing email to RockAuto about not admitting they made an error.Last edited by 1990new; 04-27-2016, 09:31 PM.
Replacing the vacuum modulator in my 92 GL automatic did not fix the up shift problem and the torque converter seal is leaking now so I will be replacing the automatic with a 5 speed within a few months.Originally posted by 1990new View PostPlease clarify.. The vacuum modulator on my 1992 GL screws in. Look at the picture of the modulators listed in the
I just wrote a scathing email to RockAuto about not admitting they made an error.Last edited by 1990new; 05-14-2016, 07:43 PM.
