so, I just found out that while trying to change my rear wheel bearings, the brake calipers needed to be replaced along with the "pads" as I call them.... the rotors needed to be turned also... hey while i'm at it, does anybody have 2 crimp nuts, the ones for the center that holds the rotors on? The PO screwed the nuts up pretty bad but not to mention the real awful brake job and the 5+ pounds of greese the PO had done and/or used....
rear wheele berrings into brake job?
Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
'94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
Tags: None
RockAuto and Oreilly's used to sell the crimp nuts, but its been a while since I've bought any. If you are talking about the rears then this terminology guide may help you out when ordering parts.
Calipers = wheel cylinders
Pads = shoes
Rotors = drums
It may be worth it to buy new drums instead of having the old ones turned. Last set of drums I bought were $16.85ea, and having them turned was going to be $15ea.No festiva for me ATM...
RockAuto! I just got a full rear-job for $97 total buying up their 'wholesale closeouts'.
2 Drums ($10/ea)
Shoes
2 Wheel Cylinders
2 sets (inner and outer) Timken Bearings
2 Wheel Seals
Brake Hardware
and something else I forget.
Included shipping. Cheapest I could get anywhere else was about $140 shipped from Advance Auto (with $40 off $110 coupon code).
-JoeWhite '92 GL 5-speed BP, G series, Aspire/Rio swapped, "Nancy"
1988 LX 5-speed
1993 L 5-speed B8, E series, Aspire/Rio swapped
Gone:
sorry for my mistake but I know more about 21st century brakes then 20th century brakes.... lol! It does not cost anything for me to turn brake drums because I work at a place (just when he has work) that lets me do it for next to nothing.... i have known the owner for years.... i think new wheele cylanders and shoes was only about $45 @ NapaLast edited by old yellow; 11-18-2013, 05:05 PM.Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
only $20 for the inner and outer barings with bolth sealsDoug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Speaking of brake parts, and wheel bearings, I keep putting off getting the grease seal installed on my passenger side.
Have ran over 10k miles without that seal. lol I know this isn't good though since all the brake dust can get into the grease and screw up the bearings.
I also made the mistake of not matching the races to the Timkin bearings, somehow I installed the Valucraft bearing races, but used the Timkin bearings, I didn't even realize this until I found the races in a box of parts with Timkin written on the sides of em. The reason for the mixup was I bought the Valucraft bearings at first, but decided to upgrade to Timkins but never returned the Valucraft ones, and the parts got mixed up.
But has been running good so far.Last edited by TorqueEffect; 11-19-2013, 12:23 AM.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
Ya and I just had the car aligned.... it is now as straight as it can get but 90% of the problem is Radial Pull from my tiresDoug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
how long do wheel bearings usually last for you guys? I was originally told they should last around 100k but Ive got one going out that I put on about 10,000 miles ago, any thoughts?89 LX (461xxx miles original motor and trans, retired
90 L (restoration in progress)
91 L (saved from abusive owner lol)
92 L (DD)
88 (model unknown, rust free, possible project)
88-89 (parts car. practically picked to the bone)
93 GL (parts car)
initial pre-load and type of grease used has a factor... plus maintinance. 50k+ on my bearings (i replace them as soon as i get a new (to me) car). i use SKF or Timkin and Moly grease, pack the bearing heavily and coat the area between the bearings (inner and outer) just to fill the air gap a little (you need some air gap, but not much). then i load the bearings very firmly, rotate the drum a few times, unload, re-load, rotate, unload and then set the tension i want (all by feel, but i've been doing this for many years).
the important thing to remember is to clean and repack your bearings regularly (i'm on a 2 year cycle, or there abouts).Trees aren't kind to me...
