I never really paid any mind to the spare tire till today. my car still has the stock 12s and will be upgrading soon but I was wondering if all festiva have a 13 inch spare??
spare tire question
spare tire question
1990 Red Festiva STOCK "pregnant roller skate"
1989 Yellow Festiva BP swap "Freebird"
2007 Ford F150 "black sunshine" full exhaust with x-pipe. K&N intake. Headman Headers.
2001 Honda accord SOLD lots of goodies done suicide doors lowered 20 inch rims
2005 Ford F250 6.0 Turbo Diesel "swamprat" 4 inch lift, 4 inch mbrp exhaust, egr delete, glowshift pillar gauges.
1994 Ford F150 5.0 Completely stock.Tags: None
I'm not aware of any full size spare options so my guess is that all Festivas came with temporary spares in the 13" size.
If you will be upgrading to Aspire hubs with their 4 X 100mm pattern, then I'd recommend getting an early Kia Rio spare doughnut, which is the same size as the Aspire doughnut, but several years newer. They also came in bias ply and radial versions. I have one of each.
Either that or go to a full size spare to match your new tires.
Don't use donuts, get a full-size 12" spare. Far more reliable and convenient if you have to go any distance with it.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I just ordered today my 14s and I will be putting one the old steelies in just in case1990 Red Festiva STOCK "pregnant roller skate"
I have an Aspire spare in mine. The problem is the fact you can't use the stock wheel well cover any more. I just went to the junk yard, got a nice clean large cover out of some other trunk, cut the hole a lttle larger so that it would fit around the steel wheel protrusion. Dropped in a plastic disc and then threw carpet over that. Just a small bump now.Last edited by bravekozak; 11-23-2013, 09:55 PM.
