do the rear Axal crimp nuts for the aspire work for the festiva? all the local junkyards have aspires but not festivas and i need the nuts asap
Aspire axal crimp nuts
Last edited by old yellow; 11-29-2013, 02:01 PM.Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
'94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
Tags: None
Axle nuts are available at auto part stores. Best to get NEW ones! Cheap! Old ones really shoudnt be used again.Dan
the nut to hold the drum on the back.... the one behind the greese cap behind the center cap.... Napa does not sell new nuts and the 3 closest auto parts stores are Napa plus i need them asapLast edited by old yellow; 11-29-2013, 02:25 PM.Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
where do you get them? Napa does not sell themOriginally posted by drddan View PostAxle nuts are available at auto part stores. Best to get NEW ones! Cheap! Old ones really shoudnt be used again.Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
now does the aspire spindle lock nuts work for the Festiva?Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Originally posted by old yellow View Postwhere do you get them? Napa does not sell them
Oreilly's usually has them in stock. If not they will get them in for you without pre-paying. Call early and they usually have them in an hour or so.
I cant believe your NAPA doesnt have them! I can get them at AZ, Advance, NAPA, and Oreilly's!
As for the Aspire rear nuts ... Look at Rockauto.com and check the Festiva and Aspire part numbers against each other!
For shame.. none of us would do that.Originally posted by F3BZ View Postnow me? ida just "pocketed" the aspire nuts from the junker and then i'd know!
If in a junkyard and it can fit in the pocket and is smaller than my wallet, you know where it goes.
...on the table... to be bought.
-JoeWhite '92 GL 5-speed BP, G series, Aspire/Rio swapped, "Nancy"
1988 LX 5-speed
1993 L 5-speed B8, E series, Aspire/Rio swapped
Gone:
To answer your original question: Aspire nuts and 88-92 Festiva nuts are different. In 93 Festys went to the castle nuts with cotter pin; no crimping. There might possibly be some 92s with the later style.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
If size and thread pitch is the same between Festy/Aspire (and I would think they are) now is a perfect time to switch over to the castle nut/cotter pin set up! Grab the JY nuts and spin them on for now, just to get back on the road, and then when it's quiet and there's more time drill through the spindle with a 1/8" bit so as to make space for a cotter pin. I switched all of my Festys over to this arrangement and can assure you rear spindles are not made of hard steel.Originally posted by TominMO View PostTo answer your original question: Aspire nuts and 88-92 Festiva nuts are different. In 93 Festys went to the castle nuts with cotter pin; no crimping. There might possibly be some 92s with the later style.
Not sure this is a good idea since the castle nuts can't be crimped. Unless you also use locktite to help hold them on. I'd recommend the red locktite, as a safety precaution. The nut can still be unscrewed, it just takes more torque than with blue.Originally posted by Bert View PostIf size and thread pitch is the same between Festy/Aspire (and I would think they are) now is a perfect time to switch over to the castle nut/cotter pin set up! Grab the JY nuts and spin them on for now, just to get back on the road, and then when it's quiet and there's more time drill through the spindle with a 1/8" bit so as to make space for a cotter pin. I switched all of my Festys over to this arrangement and can assure you rear spindles are not made of hard steel.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Yes, They are 16mm-1.5 nuts and they do not sell them for the aspire. Festiva ones will work fine.Originally posted by old yellow View Postdo the rear Axal crimp nuts for the aspire work for the festiva? all the local junkyards have aspires but not festivas and i need the nuts asap1993 Festy, 1.6SOHC, Aspire Suspension
Stripped to bare bones, SCCA RallyX
I guess all the napa's near me need to start firing some people they don't know how to read a parts book.... if it's not listed on the computer, go read the books! it's a dang dorman part.... on the other hand o'rilys found me 2 nuts for each side in the rear....Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
