Could engine sludge increase pressure causing the crank seal to leak? Also what are some good ways to make the internals gleam again? I've been putting some MMO thru it but it looks like the idiot kid Po hasn't change the oil in 15k and it needs the sludge out, so a heavy cleaner recommendation would be appreciated.
Engine sludge solutions
Its possible but they usually just go bad from high mileage.Originally posted by Corycarlo View PostI used some napa engine sludge melt. If that doesn't work I will try the trans fluid. I've heard of that old trick a long time ago and forgot about it. Would excess engine sludge cause the crank seal to leak possibly? Thanks
You're not going to stop a leak by cleaning out sludge, if anything you'll make it worse. If that's what you're getting at here.
Which crank seal is it? How far are you from Marshalls Creek? If you need help fixing it hit me up1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
My only gripe with that is that I don't think diesel fuel is a very good lubricant at all. At least ATF is a lubricant.Originally posted by bhearts View Postive always used diesel. a whole crankcase full of the stuff, and let it idle for 20 minutes.1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
