lower profile 13" tires
  • lower profile 13" tires
    want to put lower profile 13 inch tires on my festiva, what tires do you reccomend? i have 175/70/13 on now
    Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
    Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
    Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has
    it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
    Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
    TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to
    bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
    '94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
    SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
    R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
    R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
    R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
    R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
    R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
      ok
        You can go a bit smaller with 175-60s.
        Or if you want the most extreme without spending a whole load of money. 175-50s
          I run 155x80x13's KUMHO - Solus KR21
          92 GL was red automatic Ms Va., now Zinc Yellow
            I run 175s, it clears everything just fine, just a bit too tall with 70s, I couldn't imagine 80s. I do think in the past my car has been hit in the front on the driver's side, which has tweaked the frame a bit causing the driver's side to sit lower by about half a inch to an inch. I get rubbing on hard right turns, and large bumps on my driver's side with 175-70s, but never on passenger side unless someone heavy is sitting there, and it is a pretty significant bump.
            I think I may go down to the 60s to get some acceleration back, and correct the speedo, but I will move my newer 175-70s to the back. And yes I just looked it up, factory overall diameter is 21.3, and that is what the 175-60s-13s are exactly.
              Mixing 60-series and 70-series tires might be a bad idea. It's not just about the height, but also the sidewall stiffness. You might find you have some weird handling issues. But if you do this, then be sure to inflate the 70-series tires to a higher PSI than the 60s, to try to equal out the sidewall stiffness. Maybe 5+ PSI more.
                I'm running 185/60-13 Federal tires on 13"x5" alloy wheels. With stock struts I had to run 1/4" spacers in the back.
                Ian
                  Yeah, 175s barely clear my rear strut perches so it makes sense a quarter inch spacer would be needed for 185s.
                  Sent from my LG-LS720 using Tapatalk
                    Im currently running these but 185 60 13 size no problems very quiet and best of all install by Eurotiva!
                    RJ
