when putting a 1994 Ford Aspire engine in your festiva what major parts do you use? what Festiva and what aspire parts do you use?
festiva/aspire questions
Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
'94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
Tags: None
All the Aspire pulleys; OR you can use the 1993 Festy crank pulley to keep the rest of the pulleys Festy.
Festy intake, exhaust and disty. And Festy thermostat housing.
I think that's everything.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
The Festiva coolant piping will need to be retainied if you intend to hook up to the Festiva rad. The Aspire engine has a cast aluminum lower rad connector to the water pump. It is intended for use with a longer Aspire rad. The Aspire rad cannot be used used with stock Festiva A/C condenser hoses.
I do have A/C... do I need the Aspire or Festiva Water Pump? Are they the same? I think I got a new Aspire Water pump....Last edited by old yellow; 08-02-2014, 11:58 PM.Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
so as it is I can't use the Festiva pullys? also must use the Festiva distributor? will the aspire cap and roter work on the Festiva distributor? I bought a cap and roter for the aspire.... also will the aspire thermostat work in the Festiva housing?Originally posted by TominMO View PostAll the Aspire pulleys; OR you can use the 1993 Festy crank pulley to keep the rest of the pulleys Festy.
I think that's everything.Last edited by old yellow; 08-02-2014, 11:59 PM.Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Water pumps the same. Thermostats the same. Pulley and disty questions answered. For cap and rotor, use Rock Auto to cross-ref parts numbers.
Good catch on lower rad pipe, Brave. You need the Festy one, Yellow.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Ok sounds good! Will be asking more questions as I can come up with them....Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
did not fully understand the distributer.... do I take the one off the festiva or use the one for the aspire because I have a brand new cap and rotor for the aspire and not for the festiva and it loks to not be cross compatable as the parts have a different part numberDoug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Use the Festy distributor. Wiring is different for the Aspire one--you will notice there is no coil wire for the Aspire disty.Originally posted by old yellow View Postdid not fully understand the distributer.... do I take the one off the festiva or use the one for the aspire because I have a brand new cap and rotor for the aspire and not for the festiva and it loks to not be cross compatable as the parts have a different part number90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Ok now I got itDoug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Do you need to use the aspire auto tranny or can I use the festiva auto tranny?Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
do I want to also use the flex plate from the Aspire or Festiva? I don't have an Aspire flex plateOriginally posted by old yellow View PostDo you need to use the aspire auto tranny or can I use the festiva auto tranny?Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
