89 wont crank
  • 89 wont crank
    I just bought an 89 Festiva. It was cranking and and trying to fire. I did get it started briefly just long enough to move it 30 ft. I towed it home and it has been cranking. It was parked for a year so i replaced the the fuel filter. it did crank once after i replaced the filter but now it wont. Battery is charged, lights, fan, and dash lights work but it wont crank or even click. What have i knocked loose? it must have cranked 40 times before i replaced the filter. any ideas?//
    Check your fusable links?
    06 Jeep Cherokee Overland
    95 Aspire (sold)
      Check the distributor?
        When you replace the fuel filter, it is easy to knock the small starter control wire loose. I have done that before.
        "Fred" 93 Festiva L B6-ME Swap
        “Though he is small, he is but fierce.”
          Fuseable links visibly look good, should i check for power flow through them?
          What should i check on the distributor?
          Where can i find the small starter control wire. Is it under the coil?
            image.jpg Pic of fuseable links
              image.jpg Loose connector found under the coil
                Sometimes they can burn out on the inside. Check with multimeter. I replaced them with long legged fuses pink green pink.
                95 Aspire (sold)
                  image.jpg Distributor looks ok
                    image.jpg I do have three plugs that aren't connected found beside the drive strut top
                      Originally posted by gunnerw View Post
                      [ATTACH=CONFIG]16083[/ATTACH] I do have three plugs that aren't connected found beside the drive strut top
                      Those are unplugged on mine too.
                      95 Aspire (sold)
                        The starter control wire has a spade connector and is connected right on the starter solenoid. The 3 plugs you mentioned are only used during diagnostic testing.
                          Well it wasnt the fuseable links i replaced them.
                            Okay thanks ill keep checking. I assume since the 89 that I have has EFI it has a electric fuel pump,. Is that correct?
                              Since it's an 89 efi, it should be an automatic trans. Have you checked the switch on the shifter? It won't start if it's not in neutral or park.
                              Jerry
                              Team Lightning
                              Owner of Team Lightning
                              93 L Lightning. BP
