I know i need 12x1.5 threads, but what length should i choose? i founds a kit with 2.1inch (57mm) studs.
wheel stud conversion length
This has all been posted in depth,but I don't know if you can find it with this search engine....Some people like to read fiction,I prefer to read repair manuals. Weird I know-
Depends on whether you need to be using spacers or not. Use the longer BMW studs for spacers, the shorter VW studs if not.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I used 45 mm studs. I had to cut off about 7 mm on the rear wheel studs in order to get it to fit correctly. The front fit with no problem. I assume that the rotor was thick enough to make it work.
Edit:
They were 57 mm 45 useable length. Either way I had to cut some off the back. I chose to use closed lug nuts though.Last edited by Chobobulous; 08-25-2014, 10:05 PM.
1.75" is what I used too. You can use longer studs if you have the long "tuner" spline drive nuts, and then you still get closed ended nuts. Those will just about take all the threads on a 1.75" stud, so after you add the thickness of the wheel to it, it's no problem.Any difference that makes no difference is no difference.
You can also get long closed regular nuts too. Search eBay. I forgot I'd bought some for my racing steelies that will definitely get put on before I die, eventually, I'm sure.Originally posted by sketchman View Post1.75" is what I used too. You can use longer studs if you have the long "tuner" spline drive nuts, and then you still get closed ended nuts. Those will just about take all the threads on a 1.75" stud, so after you add the thickness of the wheel to it, it's no problem.
