We all know the biggest weaknesses on the g transmission. But has anyone logged the biggest weakness on each oem engine. I'm curious to know what breaks under boost. In s theoretical world where knock didn't exist, how high did you crank your boost up before your engine grenades, and what part was at fault. ?
Engine weaknesses
As over-engineered as the B3 seems to be, I would guess it was the most robust. The pistons would probably be the first fail point, but it would take some decent boost to do so, given that the motor is only designed to make 63 HP. Lots of safety overhead.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by bhearts View PostMy mechanic friend said the b3 rods are as beefy as gm 3800 rods. And those reliably make 30hp per cylinder. It's assumed that all the head gaskets are junk? I assumed that would be the first fail point90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by SiliconSoul View PostAlways wondered what the limits of the crank would be.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by jason_ View PostValves! Every b3 I've acquired cheaply was because of valve work needed.
Just too small imo
The fact that you get 'em cheap due to needing valve work probably means they didn't get regular oil changes or were high-mileage. Would you say this was true?90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Originally posted by jason_ View PostI dunno milage . Everyone had a broken cable
I wasn't aware oil changes improve valve face and valve seat performance. Noted!
Sent from my rooted HTC Supersonic using Tapatalk 2 Pro
The B3's I've torn down or assisted in tearing down had busted/cracked pistons in them. It seems to me that the pistons may be a weak spot. All had at least one bad piston in it.Last edited by Team Lightning; 09-26-2014, 01:04 PM.Jerry
Team Lightning
Owner of Team Lightning
93 L Lightning. BP
Originally posted by bhearts View PostWhat if the b3 could support 200whp. Wouldn't everyone feel like they were cutting themselves short by putting in a bigger engine?1988 Chevy Sprint Turbo 997cc
Aaron, I agree. The cost of a 200 HP B3 would be very high. Then you have the reliability issue too.Jerry
Team Lightning
93 L Lightning. BP
