Does anybody know how to make the doors not lock? I broke the lock cylinder out of one of the doors on the GL to where I can't install it back on again... plus I have a hard time unlocking the doors from both the outside and inside (only the trunk kinda unlocks)
Door locks
Door locks
Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
'94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
Tags: None
Don't push the button down before closing the door.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I don't do that already, other people have tho... but what I mean is completely removing everything related to making the doors lock so they don't.... removing lock cylinders, buttons, and everything inside the doorsOriginally posted by TominMO View PostDon't push the button down before closing the door.Last edited by old yellow; 12-23-2014, 02:00 AM.Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Functionally, all you would really need to do is undo the little clip that connects the door lock to the rod. Now it can't be locked with a key. Then unhook the rod that goes from the button down to the locking mechanism down in the door; or just remove the button and rod completely, and find a little plug to put in the button hole.
Make sure the lock is in the unlocked position when you do this!
But why would you want to make it unlockable? I don't understand why you have a hard time with the locks; maybe they just need some WD-40 or something to free them up.Last edited by TominMO; 12-23-2014, 09:46 AM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
the clip already broke off the lock cylinder on the passenger door so I can't put it back on and I just about broke the key off in the door when i tried to unlock the door from the outside... I have had people that have locked the car and it took about half an hour to get in the car by crawling over the back seat from the trunkDoug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
