spindle help needed
  • spindle help needed
    question i have is on the rear of the festiva is the washer,spindle nut,retainer,cotter key on the driver side and the passenger side has a castle nut,cotter key does anyone know what the part numbers are for these and where i can buy them at
    Stock arrangement is stake nuts on both sides up through mid-92. Castle nut and cotter pin on late 92 and 93. If they aren't the same on your car( what year is it?), one spindle has been changed out. Rockauto has the stake nuts( in 2 packs) but I don't see the castle nuts. Stock is also left hand thread on the right, passenger side, at least with the stake nut.
    "Wenona"-89L parts car
      Are you sure about that? My early build '93 had stake nuts on both sides before I did my Aspire swap.
      Axlander9289, brother of ThisVelologist
      Festivas past:
      Aqua '92 Festiva L - Sold "Dale"
      White '89 Festiva L Plus - RIP "Dudley"
      White '93 Festiva GL - Sold to thisvelologist "Frito"
      Red '91 Festiva L - Sold to Louieisawesome "Geraldo"
      Current Fleet:
      Aqua '93 Festiva L with Aspire brakes "Dale Jr."
      Black and White '93 Festiva GL Sport (White alloys and spoiler are long gone) "Blues-tiva"
      White '15 Ford Transit Connect
        Nope. Not entirely sure. My two 92's both have stake nuts and the 93 I stripped down had castle nuts. As far as the dates involved, I am going by what others have posted here. I guess it's possible that your 93 might have been changed out before you got it. I briefly considered putting the 93 spindles on my daughter's car when I had everything off to replace the beam she bent, as I am not crazy about "one use parts" like stake nuts, but one of them looked a little discolored like it might have overheated at some point. The old ones looked better to me so I left them.
          check out rockauto. I buy a lot from there.
          1990 festiva l (747 the jumbo jet) (b6t & g box)
            They won't have the washers though. I found that out the hardway.
            It is actually impossible to find the rear spindle washers new, I had to get a member here to send me one.
            Funny enough though, I am actually using the Festiva stake nuts on my Aspire swap. lol
            I just couldn't find the castle nuts for a reasonable price, so just used my old stake nuts. (Yes I reuse mine, and have never had a problem, even routinely check to see if they have moved, and they do not.
              My apologies. You were right. I just went and looked at my old spindles again and sure enough, there were castle nuts. My bad.
              Festivas past:
              Current Fleet:
