I found a source for the Spacer Selection Tool and Spacers.
and
I don't know if the Kia spacer are correct. They have the right thinkness but don't know about the inner and outer diameters. The festiva process for front bearing is like pinion bearing shim selection. I don't think I need to replace my front bearing when I do the brakes but just in case I ever do.
and
Plus, there could be slight variances in the bearings, which may require different spacers. But, usually bearings are pretty accurate in size.
