How many here have sheered off their valve cover bolts by tightening under 20lb ft?
I'm asking because today I replaced all of my tappets(which one of the bolts on the rocker arm assembly has cross threaded the hole), and while screwing the bolts back in, one of them sheered right off. I set the torque on my wrench to 19 foot lbs and it didn't even click before the bolt sheered off. Of course, two other bolts were sheered off by one of the P.O.'s, and now the cover's being held on by 3 bolts.
SO frustrating. Now I have to drill out the holes and re-thread them. I was just about finished getting the festy back on the road when this happened. Does anybody think it's a bad idea to drive it as it is right now? Of course, I did a little check on the cover to see if it would budge by using my hands to try and move it around, which it didn't budge.. still, I don't think that's a good enough test, but I wonder if it would be good enough as a temporary placement, while I wait to get the messed up bits replaced. I also am going to buy a set of grommets from rock auto, since the old ones are super cracked and crap.
What's the torque specs for those valve cover bolts anyway?
I tightened all the rocker assembly bolts down to 19ftlbs, which I'm sure is acceptable. I don't have a manual or anything, just found what I could online. If anybody has a complete list of torque specs, I'd appreciate the documentation...
Thanks!
Thanks!
