what are the Aspire Airbag blink codes? would like to know before I go to take a look at an absolutly perfect aspire with a flashing airbag light
Aspire Airbag Blink Codes
Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
'94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
Tags: None
There are 17 different airbag codes. As listed in factory service manual.
Code=
--=no airbag warning indicator-inoperative lamp circuit or no ignition voltage to airbag diagnostic monitor
--=continuous airbag warning indicator-airbag diagnostic monitor disconnected or inoperative
12=low battery voltage,
13=airbag or primary crash airbag sensor circuit shorted to ground,
21=center cowl safing rear airbag sensor not mounted to vehicle properly
22=center cowl safing rear airbag sensor output circuit shorted to battery voltage
23=center cowl safing rear airbag sensor circuit input feed/return circuit open
24=center cowl safing rear airbag sensor output feed/return circuit open or low resistance in a primary crash airbag sensor
32=driver side airbag module circuit high resistance or open
33=passenger side airbag module circuit high resistance or open
34=driver side airbag module circuit low resistance or shorted
35=passenger side airbag module circuit low resistance or shorted
41=primary crash air bag sensor circuits high resistance or open
44=rh fender primary crash front airbag sensor not mounted to vehicle properly
45=radiator primary crash center airbag sensor not mounted to vehicle properly
46=lh fender primary crash front airbag sensor not mounted to vehicle properly
51=airbag diagnostic monitor internal thermal fuse-fuse blown due to intermittent short to ground
52=back-up power supply-voltage boost fault
53=airbag diagnostic monitor fault
--=rapid continuous flashing of airbag warning indicator (No DTC)-all primary crash airbag sensors disconnected
What are the flash patterns to indicate each code?
Sent from one of my 2 iPhones using TapatalkDoug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
