Putting a 91 Engine for a MT in a 93 with AT.
  • Putting a 91 Engine for a MT in a 93 with AT.
    Help me if you can. Any issues switching a 91 engine for a MT Festiva into a 93 AT model? For example, do I need a new computer or other things?
    Thanks
    Computers are the same.Starter and wiring harness flywheel ,fly wheel cover need to be for an auto,and the auto has a round metal peice in the center or behind the fly wheel.
      So autos don't have different computers than manuals? That's surprising.
        You got me pondering.For his motor swap he is fine.I have swapped from auto trans to manual without swapping computer but perhaps going from a manual trans to auto you might have to change the computer idk.
          I believe the auto needs the three plug ECU not the two plug for standard tranny!!!
          Chuck
          91 GL -Ol' Rusty
          93 GL - Lil Red
          91 L - Tweetystiva
            Correct
              ^ but is it possible to switch an auto to a manual without messing with the wiring/computer too much
              88 L carb'ed (when up in flames of glory)(deceased) 4spd
              89 L carb'ed (died on the operating table (rust))(deceased) 5spd
              93 gl FI (sold) automagical
              89 lx FI megasquirted "luna" b6D+t (186hp 209ftlbs)
              88 L carbFI megasquirted zombie car
                My 93 auto has a 2 plug ecu as well as the other 2 auto i swapped over to manual were 2 plug,could it be that the 88-89 auto is a 3 plug and 90-93 2 plug?
