has anyone ever found a way to reseal the seam weld on the notoriously leaky festiva gas tanks mine has a slight leak
gas tank leak of doom
Also, remember the 2 door Aspire has the same tank as an FI Festiva, so if you can get a good used one from a later model Aspire that will work even cheaper.
Cause, cheapness is it's own reward.
i paid close to 300 for the tank for my bronco altho i opted for the plastic aftermarket tank for obvious reasons living in the north88 L carb'ed (when up in flames of glory)(deceased) 4spd
89 L carb'ed (died on the operating table (rust))(deceased) 5spd
93 gl FI (sold) automagical
89 lx FI megasquirted "luna" b6D+t (186hp 209ftlbs)
88 L carbFI megasquirted zombie car
they look like a pretty simple shape i wonder if someone could vacuum mold the 2 halfs and glue/plastic weld them together88 L carb'ed (when up in flames of glory)(deceased) 4spd
I replaced mine no too long ago. Here's a few posts about itIan
Simple shape yes, if i had a slightly bigger rotocaster at work i could make it in one piece but just the materials for the mould would be above $2000, not to mention labour.Originally posted by monkeykiller1996 View Postthey look like a pretty simple shape i wonder if someone could vacuum mold the 2 halfs and glue/plastic weld them together
I didn't think it was too common on the festivas but i could easily be wrong. Older accords it was almost guaranteed to happen to. I was looking on ebay yesterday at expensive festiva stuff and i was surprised to see brand new gas tanks but you know what surprised me more? This: http://www.ebay.ca/ulk/itm/161561170886
A brand new B3 block.
