just wondering what kind of penetrating oils that everybody uses im a fan of pb blaster but haven't tried many other kinds (wd-40 and liquid wrench)
penetrating oils
just did a quick search is this what you use, its pretty cheap if it is, how good does it work, i live in the show belt so good penetrating oil is like gold
88 L carb'ed (when up in flames of glory)(deceased) 4spd
89 L carb'ed (died on the operating table (rust))(deceased) 5spd
93 gl FI (sold) automagical
89 lx FI megasquirted "luna" b6D+t (186hp 209ftlbs)
88 L carbFI megasquirted zombie car
I've heard ATF and acetone beats everything, but I've never tried it.Any difference that makes no difference is no difference.
Its caustic and dont get it on paint. There is a tech at my job that makes his own "super penetrate". Same as what your saying only using brake clean and ATF.Originally posted by sketchman View PostI've heard ATF and acetone beats everything, but I've never tried it.Lil' Red Rocket '93 Festiva: Stock, A/C, Rear wiper, Rear defrost, Alloys, Power mirrors, White Tach,Super tail action (factory spoiler)
Frogstiva '92 Festiva: Just bought a HOT MESS. BP swap with E trans (not done), Built Red from factory spray bombed black with stripes, Aspire swap, Escort GT Master Cylinder, found frogs in vehicle, hence Frogstiva, pulling all good parts for Lil' Red Rocket.
1.7 PN Diesel and trans, waiting for good shell.
Hmm. Well now I have to try it.Any difference that makes no difference is no difference.
I use Releasall...
i have to change some 30+ year old balljoints next week(all 30 years in the snow belt) and i was looking for something better than what i usually use i don't think blaster is gonna get it done88 L carb'ed (when up in flames of glory)(deceased) 4spd
Yeah, the ATF plus acetone works incredibly well. And is cheap! Basically ATF plus any solvent that it will kind of mix with will do the trick. Brake clean is mostly methanol, and ATF will not mix with it very well. I have tried some other things but always come back to the tried and true ATF plus acetone formula.
Hmm, I just used some Google Fu, and found some interestings.
http://www.engineeringforchange.org/how-to-make-penetrating-oil/
So, grab some veg oil next time you're in the grocery store, and thin it with whatever would mix readily with oil. I'd say something petroleum based would work better than acetone even. From what I found acetone doesn't really want to mix with ATF.
I think I'll try veg oil and gasoline right now and see what they do.
EDIT: Just mixed up some kerosene and veg oil. They mix perfectly, and so far they are staying mixed. I will let it sit overnight and post another pic, but as of now I'm taking this to work to try out. Oh, and funny enough it smells very much like PB Blaster. Hmm.
Last edited by sketchman; 11-14-2015, 03:53 PM.Any difference that makes no difference is no difference.
A lot of guys on Garage Journal like Kroil, but you can only get it direct from the mfg.1963 Fairlane - future NSS drag car
i think im going to try the atf and acetone i already have those thing laying around maybe if i keep soking it for the next week i can get the nut off by hand :glasses2:, the kerosene and veg oil thing sound interesting too88 L carb'ed (when up in flames of glory)(deceased) 4spd
