festiva not running right
  • #16
    I think I will try and find a new intake tube and hope that fixes it. Thank you all for the help I appreciate it.
    1991 ford festiva 5 speed 140k miles, yellow
    1993 festiva 5 speed 60k miles, white
    • #17
      Maybe try getting a can of maf(mass air flow) sensor cleaner and cleaning you maf sensor. Maybe it is contaminated? It is located above the air filter. It may be worth taking a look even if you don't clean it you may be able to see a small piece of crap on the wire filament that is causing your rough run. I also would want to check fuel pressure.
      I hope this helps.
      • #18
        sorry guys I only saw the first page of comments. It looks like you have it figured out
