Some Aspire/Festiva noob questions
  • Some Aspire/Festiva noob questions
    don't know if this the correct place to ask but feel free to move if necessary.....
    __________________________________________________ __________________________________________________ __________________________________________________ ______
    Will the B3 complete power steering from the Aspire work on an Aspire with the BP engine?
    What is the difference between ABS and Non-ABS Aspire Brakes? will ABS variant still work for the break swap?
    Will the Aspire Steering wheel fit the Festiva with or without modification? what is the safest way to remove the wheel without airbag in your face?
    Will the Aspire A/C compressor and hoses work with the rest of the Festiva A/C system? What is needed to get the Festiva A/C system working with the Aspire compressor?
    Will ask more questions as I can think of them.....
    Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
    Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
    Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has
    it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
    Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
    TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to
    bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
    '94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
    SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
    R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
    R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
    R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
    R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
    R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
    bump
      Ac aspire bp ? Yes
      abs brakes for swap . Yes just remove sensors .
      steering wheel fit, should but trim won't . Air bag , remove battery completely then unbolt bag .
      Some of the late 93 Festy ac lines would work but it's best just to use a complete system from said car .
      Good luck with the bp swap its a real pain .
      New build on the way .
        Originally posted by shadetree View Post
        Ac aspire bp ? Yes
        Thanks! so B3 Power steering will work on the BP engine?
        so take the complete Aspire A/C and install it in my Festiva? what should I take? and where is it located?
        Just want the steering wheel and nothing elce around it.... just use the festiva trim
        ya I gotta install the BP in the Aspire SE
          As far as removing the steering wheel without the airbag blowing up on you, it is recommended to disconnect the battery and wait 5 to 10 minutes before removing the airbag
            ok! ya I need to replace the wiper switch on the SE! might do that this weekend!
              Yes power steering will work . You will have to bend the lines and tweak things alittle but yes it will work . And ac us aspire ac in aspire and festiva in a festiva . Use original system from said car . As for listing every part , you should think about this swap alittle more if your not sure of the parts needed.
                As far as the steering wheel, I assume you want to retain the horn. There are two connectors under the steering wheel airbag, one for the airbag and one for the horn. The Festiva uses a simple spade connector for the horn, while the Aspire uses a more involved plug-in connector. I think you can just replace the connector on the Aspire steering wheel with a spade, to match the Festy one.
                Wiper switch: A couple of years ago I noticed that another Ford car from the 90s, IIRC a Contour, used the same style wiper switch as the Aspire. But instead of single-speed delay, it had variable-speed delay. The wiring was not like on the Festiva tho, with all the connections made right at the wiper module; you had to go further down into the steering column to get at the connector. Presumably the Aspire is the same. I wish I had gotten it at the time, and am now on the lookout for one. IDK if all trim levels got the variable-speed delay. Contours came out in '95, so I'm pretty sure that was the model. Mercury Mystique is the same car BTW. Wouldn't hurt to look at other Ford models, starting with ~1994.
                  ok cool! I have all Aspire pulleys in my Festiva..... how would I get an Aspire A/C compressor with the Aspire Pulley to work or how would I put an Aspire Pulley on a Festiva A/C compressor?
                  The horn on my Festiva and parts Aspire doesn't work anyways.... I could get it to work if I wanted to but I just live without it..... as far as the wiper/turn signal switch, it's not going to be installed on my Festiva, it is going on The Aspire SE.... besides the contour from pictures I've seen, it uses a totally different wiper switch.....
