....I use "Fuelly" to keep track of my mpg. I've gone from 40, 39 mpg in Aug. through Oct. and this last fill up I got 35!! What the heck? Before that was 36, before that was 37. So a steady slow descent.
I know gas mileage goes down in the winter but come on...
"Winter" gas?Ian
Loosing 10% on your gas milage is normal for most vehicles weather its a van, truck or small car. Oil, grease and coolant is colder on startup so there are high pumping draws, they take longer to heat up- especially oil. You use your headlights and heater more and there is more rolling resistance from winter tires, snow/slush/water. People also tend to let their vehicles idle to warm up.
Also, cold air is denser, so at hwy speeds it will create more drag than in the summer. Atmospheric drag is negligible below ~45-50 MPH.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Won't cold air, being denser, require more fuel per unit volume of air to obtain a suitable mixture?
Also, dry air is denser. The past four days in Seattle have been cold and very dry, with rare clear blue skies and visibility in excess of 100 miles at ground level.88L black, dailydriver
88LX silver a/c, dailydriver
4 88/89 disassembled
91L green
91GL aqua pwrsteer
92GL red a/c reardmg
1952 Cessna170B floatplane
Another thing to note is that the engine management richens the mixture while the engine is below operating temperature, and the oxygen sensor is not used to fine tune the fuel mixture. Festivas have a tendency to run cold, especially in cold weather.
One trick to help with this is to switch to a dual element thermostat for a 1.6 miata. These thermostats work better for a quicker warm up and a more precise control on engine temperature. They are a bit on the expensive side though.Last edited by Advancedynamix; 01-07-2016, 11:38 AM.Driving for me is neither a right nor a privilege. Driving is my passion, as it was for the people who invented the automobile, the people who paved the first roads and the people who continue to improve the automobile. Please respect this passion.
They are a little expensive as you say, but the fuel savings will more than make up for it. Guess I'm finally gonna have to get one, not so much for gas mileage tho as for better heat. I'm finally coming around to wanting to try the dual-stage t-stat to see if it really matters.Originally posted by Advancedynamix View PostAnother thing to note is that the engine management riches the mixture while the engine is under operating temperature, and the oxygen sensor is not used to fine tune the fuel mixture. Festivas have a tendency to run cold, especially in cold weather.
One trick to help with this is to switch to a dual element thermostat for a 1.6 miata. These thermostats work better for a quicker warm up and a more precise control on engine temperature. They are a bit on the expensive side though.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Here is a link to an article that explains most of the reasons for lower gas mileage during colder weather.
http://wxbrad.com/why-cold-weather-g...r-gas-mileage/
