Escort gt motor swap???
  • Escort gt motor swap???
    I have an 89 carb festy that the rings are shot in and idk what to do. Will a escort gt motor bolt in a all stock festy ?? Need serious help
    Sent from my XT1585 using Tapatalk
    Yes but your carb car is gunna be more challenging you need to go efi . Or make a manifold and carb the bp.
    Unless you already have the bp I say get a first gen b6 and use the festiva intake . Or get another b3.
      What all would I need out of a efi festy to put it in mine I know of one at a pick n pull
        I think you would probably need the entire wiring harness, fuel tank, lines and pump to start with. Not sure on what else though.
        Ian
          OK so I would like to go the easiest way with a motor swap what would that be
            B3 long block.
              Originally posted by TominMO View Post
              B3 long block.
              Could you be more specific in what I will need to do the whole swap. Ive never attemted a swap
                B3 is the stock engine. He's saying the simplest thing is just swap in another stock engine.
                Being carbed hurts swapability immensely.
                You posted this a while ago.
                Have you swapped to an Escort carb yet? If yes, any other swap you want is just a custom or modded manifold and a rejet/tune away. If not, you're in for a bigger job if you want to swap to EFI too.
                  No I haven't swapped carbs because before I found the forum I bought a rock auto carb for 315 and just got it runni g right
                    Does anyone have a b3 for sale
                      B6d and b6t are actually just as easy on a carb car !
                      New build on the way .
                        Someone's gotta be brave enough to make a carb setup for the bp. I feel like it'd sell like hot cakes
                          There is a bp with bike carbs on it somewhere.
                            this one?
                            Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
                            Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
                            Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has
                            it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
                            Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
                            TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to
                            bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
                            '94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
                            SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
                            R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
                            R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
                            R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
                            R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
                            R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
                              I'd hope not. That's my least favorite swap ever
