I will be starting to take brakes off this weekend... I do know I need all of the listed parts but what will else will I need? I have a 1997 Ford Aspire 4 door with ABS and will be using a 175/70/13 tire with rim that has an offset of +38.00 MM
Drivers hub/spindle assembly
-Passengers hub/spindle assembly
-Both Aspire calipers
-Both Aspire Tie-rod ends
-Both Aspire Rotors
-Aspire Trailing arm with Drums/Hub assembly attached and metal and rubber brake lines in place
-Aspire e-brake cables
-Both Aspire Rotors
