Some things shouldn't be done.
  • Some things shouldn't be done.
    Mile marker Mo 21 northbound I55 around 2 pm today.
    A Festiva pulling a car dolly! There's a Festiva sitting at a house close to mile marker 26. Interested in seeing if the car is still there. Or if a dead festiva is on the side of the road tomorrow.
    Will anybody on the form fess up to doing this? I can see someone using a tow bar for a short distant and slower speeds. But trying to pull a car with a dolly on the interstate?
    It would work for a 5 speed festiva as the one that's not on the dolly but don't try with a auto festiva... Will burn the clutch disks
    Sent from one of my 2 iPhones using Tapatalk
    Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
    Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
    Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has
    it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
    Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
    TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to
    bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
    '94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
    SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
    R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
    R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
    R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
    R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
    R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
      For a challenge, you could try this;
        What size car were they pulling? I could see a small hatchback or Miata being easily towed, since I used to load my Aspire with 1,000 to 1,500 lbs worth of semi-truck axle parts & it never had a problem with the clutch, brakes, cooling, or suspension. It actually rode like a Cadillac.
          I believe Damkid pulled a 323 GTX with an Aspire from Virginia to Ontario.
          Also old yellow if the car is on the dolly the drive wheels arent turning.
          91GL BP/F3A with boost
            http://www.chonday.com/Videos/trailerghu4
            That was amazing! The best was when he pulled out to pass.
            But for towing i pulled a 3600 pound 1989 cutlass supreme 50km and my car still runs fine. i took gravel roads and didnt do freeway speeds though.
              It's not a big deal.
              Rosie, 1.3 w/auto on the way to Phoenix
              No car too fast !
                I pulled a bp swapped festiva, full of tools and parts, with my festiva from Florida to NC. 650 miles @ 75/80mph. 23.9 mpg with ac rockin
                800lbs motorcycle etc....
                -Greg
                Redneck Engineer
                FOTY - '09
                  My trip average ( I towed an Aspire back ) was only 21.1 mpg
                  No car too fast !
                    [ATTACH=CONFIG]19137[/ATTACH]
                    Nice! I like it looks a bit top heavy somehow... Any problems with it swaying?
                    And a question to both you guys: did you have stock or aspire brakes and how was the stopping power?
                      With this trailer,68 - 75 lbs toung weight works well, any less and it will sway.
                      Aspire hubs, knuckles, and axle swap (torsion bar cut out), Festiva front springs, early Miata rear springs. Negative camber all around. Mk5 VW bump stops all around. Miata booster and master. 14x6 Miata alloy wheels, 185/60-14 tyres.
                      No stoping issues.
                      I should mention the stoping was just as good with the stock booster and master till the master failed. We can't seem to get Festiva masters worth a $h1t out here.
                      No car too fast !
                        Aspire front brakes, kybs and FMS springs. Stopping is fine, Just needs more room to stop.
                        -Greg
                        Redneck Engineer
                        FOTY - '09
                          Ok thanks. Im thinking about pulling a 1000-1200 pound trailer with a stock festiva through a hillier area. I think it will be fine. I put 700 pounds of sheep wool in the back of the festiva and drove 150km and it was fine other than bottoming out over every bump. This is still a long ways off and i might not do it, but thanks for the replies.
                            I pull a trailer with mine and once took 1200 pounds of steel to the scrapper on a stock ride. About 15 miles and it was alright, but that would be pins and needles for a long ride. You want to stiffen up the suspension a little and if you can, a B6 swap would be nice. I even flat towed an F150 about 3 miles, but that was SCARY!
                            B6 swapped, and a little extra rear spring, and I can flat tow a Festiva all over the country no problem. Pulled an Aspire with a tow dolly once, would consider heavier cars as well, but not with one of the Uhaul heavy duty dollies.
                              I've towed loaded U-Haul enclosed 4x8 trailers several times recently, once from Boston to DC, later up to Detroit, all on Interstates. See photo.
                              I try to keep the speed to about 55 (obviously in the slow lane), and have only done these long hauls on weekends to minimize traffic. I once jackknifed on a cross-town run on I-94 in Detroit doing about 30mph during a snowstorm -- people certainly give you plenty of room after seeing that!
                              I follow U-Haul's instructions and load such that the hitch goes down about one inch during loading. I get about 27mpg towing using this '93 manual. The hitch is custom made to attach to the strong rear tie-down brackets found on the later years (definitely not on 88s/89s). I think these U-Hauls weigh about 900 lbs empty, so my loaded weight was pretty substantial.
                              88L black, dailydriver
                              88LX silver a/c, dailydriver
                              4 88/89 disassembled
                              91L green
                              91GL aqua pwrsteer
                              92GL red a/c reardmg
                              1952 Cessna170B floatplane
