cutting axles
  • cutting axles
    Anything other than a plasma torch that will cut axles? The sawsall with the metal blade wont even nick them, god.
    And the car is up on its side so I can only get the top one out. I though the SA would have cut through them guess I should have checked before rolling the car.
    Logan
    Get a right angle grinder and put on a thin cut off wheel. Will go right thru it.
      I've cut them with a oxy/acetylene torch before, no problem.
      93 GL modyfied!!!
      :fish:
        Use a sawzall with a composite/cast iron blade or an angle grinder..
          yeah, I cut a set with a die grinder w/ cut off wheel..
            used the grinder blade, besides almost loosing a finger because the blade was too big to have a gaurd on It cut really well.
            Thx
