Hi im jeff! I bought an 89 festiva last week. Great car really nice condition for as old as it is. Only noticeable problem I'm having with it is, it is idling really high. I've messed with the idle screw and that hasn't fixed the issue. Its weird it will start idling high, tap the gas and it will go down then jump back up. It also revs up when the heat is on, if I turn the heat fan off it will barely idle almost to the point of dying, eventually it does die. I'm guessing this could only be a couple of things. Vaccum leak/disconnected line. Throttle position sensor. Carburetor issue. It is missing the tube that connects to the to the carb, no air box, the line has been capped off. Not familiar with these cars and it's ben 20 plus years since I've had a carb car, any input will be appreciated.
Also, the heat works but only in the defrost and foot selection, it blows out cold air in the face vents. Suggestions?
