Mazda 1.6L DOHC 4-cylinder
  • Mazda 1.6L DOHC 4-cylinder
    for my stock 1.3 festiva manual 1993
    motor swap from a
    1991 Mercury Capri automatic
    thoughts / concerns/ sugestions/ advice ??? its on local craigs list
    my 93 has 220 thousand miles, leaking oil but running good,, i'm not looking for a turbo car want to keep the mpg/ dependability ,, just thinking about pulled and freshening my motor soo was wondering about moving up to a B6
      I have the dohc 1.6 in my 90. It's a blast! It's the motor it should have been born with.
      Jerry
      Team Lightning
      Owner of Team Lightning
      93 L Lightning. BP
        thanks team lightning basically looking for swap info/ issues
          Advancedynamix is the guy to talk to. Its a really easy swap. According to him you can run it on the factory EFI setup no problem. So no wiring, injectors, ecu, etc.
          Its a great balance of power, mileage, and drivability. Very smooth and managable.
          91GL BP/F3A with boost
            yeah I was just reading through his sticky, any problems with it being an auto car swapping to my manual
              Throttle body type.
                Wire it like the b6t and your good to go or run it on b3 electronics like Brad said. I'm running mine one the capri stuff super easy . The auto and manual capris where the same wiring I believe they had slightly lower compression ratio and different cams then the manual but I could be wrong on that.
                My b6d is from a manual car and has good power and gets 40+ when I'm not driving the crap out of it .
                Heck it still gets 35 when I'm running it pretty hard.
                  ""One thing to note about all of these engines is the ECU and TPS differences between manual and automatic transmission cars. The throttle position sensor is different between manual and automatic transmission cars and will not interchange. Manual transmission cars have a 2-plug ECU while automatic transmission cars have a 3-plug. These ECU's will not interchange without serious splicing!! It is best to get an engine from a car with the same transmission that you have.""
                  this is the sorta reading that worries me
                    I believe that's from the BP guide though right?
