20 MPG 89 Auto
  • 20 MPG 89 Auto
    What do you think could be causing this? The vaf moves freely, the exhaust is split around the cat, and it has metro 13s. The suspension and brakes are stock. I know the tank leaks a bit, but only if it's above three-quarters.
    Sent from my LG-D950 using Tapatalk
    1990 White L-Plus 5-speed rust-machine
    Scrapped
    1991 Blue L 5-speed
    daily driver, intermittent project
    1993 rustless wonder
    A shell, awaiting suspension, brakes, and B6T
    Stuck breaks, bad coolent temp sencer and, pulling a boat anchor?
      Those first two might actually be applicable
      Scrapped
      1991 Blue L 5-speed
        The temp gauge never climbs off 0. I figured it was bad thermostat.
        Scrapped
        1991 Blue L 5-speed
          You can't actually calculate mileage if you can't fill it up...
          91GL BP/F3A with boost
            Check your ignition system, especially the advance. May also want to pull a compression test.
              I can fill it up. It just has a slight leak. Like barely anything... maybe lost 1/10 of a gallon over the 2 hour period it stays above 3/4.
              Scrapped
              1991 Blue L 5-speed
                A gas tank costs like 3 tanks of gas lol
                  I actually have a spare. I just haven't had time to install it.
                  Scrapped
                  1991 Blue L 5-speed
