steering rack saddle bracket / isolator?
  • steering rack saddle bracket / isolator?
    so the bracket that holds the steering rack to the body , saddle bracket , is there a bushing/ isolator with the bracket? can I order this part new? do I need to?
    thanks
    john
    one is a D shaped bushing. that was easy to get. the other is a meatier bushing. that was impossible to find even when parts were still available from ford. was able to get it from a JDM source but i'm not 100% sure its for the steel rack or AL rack till i get under the car
      just checked. none of the ford OEM bushings available. this was available from 4G recently. the one on the right should fit drivers side.
